Which radiator do you prefer?
  • Cyrix2k
    • 593
    #46
    Originally posted by BenjaminButtton
    Gotcha, so you just removed the tank from its attachment point and have it kinda hanging there off to the side?
    exactly, just make sure the tank is the high point in the system. The only hose that goes to the radiator is the very small one that runs to the cap of the expansion tank. The hose that goes to the bottom of the expansion tank comes off the spiderweb hose under the intake manifold - I think the comparable hose on the m20 ran to the water pump. This one does too, but the access is from behind the water pump - tee the line between the head/heatercore & water pump if you need to. That's also why I wrote that the tank is really just an overflow tank above - once the system is filled & bled, it really only is an overflow tank. BMW just has a weird way of doing things.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
    • BenjaminButtton
      • May 2012
      • 275
      #47
      Thanks a ton Cyrix, I got it all hooked up last night!
      I'm going to need a longer small hose at some point to mount the tank how I like it, but that can wait until I get the damn thing running (didn't start).
      Early models do it better.
      '86 Cosmos Sedan LS1
