Here's the setup. I have a 99 M52 ODB1 with m50 intake, 21.5 injectors, s52 cams, light weight flywheel, 540 MAF with 3.5 intake boot. rebuilt my head ( changed the valve seals and resurfaced ) and after starting it once a week for less than 10 seconds everything was fine. Tonight I installed my TRM chip designed for my setup, I let it run outside for 2-3 minutes and it was puffing blue smoke from the headers.
Could it just be a build up of crap and oil from not letting it run for long?
It started puffing on the first start with the tune so can it be that's its keeping the valves open longer because of the S52 cams?
I doubt it's a piston ring because it was not doing this with stock chip.
