Overheating issues with S50
  • e30austin
    • 15382
    '89 325i with S50. Using late model M20 radiator/expansion tank and 80 deg thermostat.
    Yesterday, I pulled the radiator to put wire up my SPAL fan (sick of using the stock AC fan.) I realized the radiator looked kinda clogged, so I attempted to flush it with a hose. Thought it worked, but clearly not. Started car up, turned thermostat to hot, turned blower on and left cap off. Appeared to bleed out fine, so at the end of the day, I went home.
    Made it on the freeway about 3 miles away and saw the temps creeping up, so I clicked the fan on and kept going. Got another mile down the road when I saw steam coming from under the hood. Pulled over and popped the hood to find the cap had been blown off the expansion tank. Let it cool down a bit, started it up, added the necessary amount of coolant, saw it appeared to be acting normally and got back on the road, and then it started to overheat again. Repeated this about 3 times over the course of an hour until I finally got it back to the shop.
    I thought maybe I didn't bleed it well enough, so I parked it on a hill at the shop and tried to bleed it to no avail. Felt the radiator and found a cold spot, so I ordered a new Nissens unit. Installed that this afternoon, parked it on the hill and attempted to bleed it again with cap off, heater set to hot and on full speed. Still doing the same damn thing, only now, it's staying right above the half mark and the temp comes down slightly when I rev it up to 3k. Then, after a while, it starts to overheat again.
    I've never had this much of an issue bleeding coolant, particularly on 24v cars with M20 radiators. Normally they just bleed themselves. I never let it get into the red, but I know M/S5X are prone to having HG issues. Hoping this is not the case. It was fine before, would have to kick the fan on if idling for a while (probably because of the old shitty radiator) but never had any issues like this.
    Any help is appreciated at this point. Thanks.
  • e30austin
    • 15382
    Bump. New thermostat installed, still doing the same thing. Even drilled a hole in the thermostat to ensure it was bleeding out all the way.
    Not sure what I'm doing wrong. Still no oil in the coolant, or coolant in the oil, so I think head/HG are ok.
    • butters
      • 1202
      That is a bummer, I'll say a prayer for your cylinder head. You replaced the water pump, correct?
      • e30austin
        • 15382
        It was replaced with an S52 metal impeller water pump at some point. I took it out and inspected it before installing the engine in the car.
        • Wh33lhop
          • 11705
          Ugh. I fucking hate cooling system issues.
          Sorry, nothing else to add to this thread. I just fucking hate cooling system issues.
          paint sucks
          • TheRealE30kidd
            • Jul 2010
            • 496
            had the same problem when I was using the M42 radiator
            The Current Army
            -(UnderConstruction) 1991 330iS 24v S52 build thread
            -1992 325iC
            -1987 E30 Truck
            -1991 332iS (BecauseRacecar)
            -1988 Dinan M3
            -1988 325iX Tribute car
            -1989 320i Touring (S52/6spd)
            • jink0619
              • 808
              What coolant are you using?
              E30love
              • edsel1134
                • Apr 2013
                • 194
                Use BMW coolant for the S50.. I've owned so many e36 m3s and have seen the waterpump fail like this randomly? When was the last time it was replaced? If u don't know order the oem replacement but with the metal impaled.. Try that
                • edsel1134
                  • Apr 2013
                  • 194
                  Impeller •
                  • jink0619
                    • 808
                    You are right, ive done 3 swaps so far and with the m52 and s50 i used prestone and both kept over heating, but my lastest swap i used bmw coolant and its been running nice and cool. Also when u go to pour the coolant in forget all the bleeding n doing it on the hill or in the bushes..watever, just pour it in slowly...nice n slow :D
                    E30love
                    • edsel1134
                      • Apr 2013
                      • 194
                      Agreed the BMW coolant stops warping of the heads from extream heat.. I seen what the BMW coolant bs others does inside these motors it's crazy.. Good luck op keep us posted
                      • edsel1134
                        • Apr 2013
                        • 194
                        Sorry helps prevent not stops lol
                        And it's worth the inflated price.. This is why I've had trouble debating the s50 swap myself.. They are sensitive that's why I got rid of my m3 lol
                        • butters
                          • 1202
                          Agree on coolant. I also add some water wetter.
                          Hate to say it Austin, but I would probably be moving towards replacing the water pump at this point just to be sure.
                          • e30austin
                            • 15382
                            I fucking despise cooling system issues, too. Only used OE coolant in this motor.
                            Water pump was nice and quiet at the time of install and showed no signs of failure. Since I'm working on basically an unlimited budget at this point, I guess I'll just replace it.
                            Also, another thing to note...heater core appears to be leaking. The carpet does feel pretty damp. Wonder if it's clogged and caused the orings to start leaking? Sure would explain a lot.
                            • edsel1134
                              • Apr 2013
                              • 194
                              Pressure leak? From air? Who knows start with pump it's cheap and easy to do.. And idk what the swap intells but check the fan clutch or what ever is used
