Ok, well I am going to figure out how to do this without tapping the head.
This is what I got for ohm readings and other misc info that might be helpful
e36
EDIT: that info on here was the damn IAT sensor..
e30
s14
2k ohms at 25 cel
1568 ohms at 31 cel
m20
91 F low speed fan kicks on
99 F hign speed fan kicks on
m10
GAUGE READINGS!!!
Coolant temp (F) Gauge sensor (ohms)
186 64
166 73
161 87
145 126
137 143
122 200
107 267
99 309
89 367
81 440
Part Numbers
m10
04 TEMPERATURE-TIME SWITCH 35CEL 8S 13621274630 $72.54
06 TEMPERATURE SENSOR, WATER 20CEL 2500 OHM 13621357414 $44.36
08 TEMPERATURE SENDING UNIT/WARNING CONTACT 45CEL 12621285073 $64.17
m20
12 ENGINE COOLANT TEMP SENSOR 1-POL 1 12621710512 $17.52
13 TEMPERATURE SENSOR, WATER 20CEL 2500 OHM 13621357414 $44.36
s14
05 TEMPERATURE SENSOR M12X1,5 13621709966 $32.36
07 ENGINE COOLANT TEMP SENSOR 1-POL 12621710512 $17.52
s52
14 DOUBLE TEMPERATURE SWITCH 13621703993 $19.75 +core
If anyone can find some more ohm info so I can find the right setup post it up. I dont have a bently for every BMW :)
e36
e30
s14
2k ohms at 25 cel
1568 ohms at 31 cel
m20
m10
GAUGE READINGS!!!
186 64
166 73
161 87
145 126
137 143
122 200
107 267
99 309
89 367
81 440
Part Numbers
m10
m20
s14
s52
