S50. M42 rad.
Here is the situation. The car will just not stay bled. It is ok for a few weeks then gets worse again. As the weeks go, the radiator hoses start staying pressurized after cooldown. Last time I was on the highway and turned the AC on and the temp started to climb. Once it passes a certain point, it likes to 'hang' above the normal mark. When I release the cap, i hear whoosh and the water level in the overflow tank usually rises. I can squeeze the upper heater hose and feel it has air in it.
Replaced rad hoses, waterpump, thermostat. Checked heatercore for leak. Don't see any leaks. When I had pump out and thermostat I put the hose in the engine output and flushed it in reverse to dislodge anything that may be blocking the channels. I did the same with the radiator and it seemed to flow out the other side without issue.
I just checked the coolant with a combustion gas checker. Nothing.
Anyone have any thoughts? I wasn't hoping it was a headgasket leak (trust me), but at least it would explain something.
Edit: The only thing I can think of is there is a sealing leak on the suction side of the pump and it pulls in air, but doesn't leak. OR the heatercore has a small leak and it sucks in air as the system cools...but then why doesn't it leak when it is pressurized?
