24v swap with auto DME
    eye balling a doner car with a auto trans eny considerations on the wiring side i have to worry about. i should just have to wire it so the car contently thinks it's in park or neutral right?
    for ref the car is a 94 325is
    Same question here.
    SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
      are you converting to manual?
      2008 335i - n54b30
      1991 318i - m52b28
      1994 fzj80 - LAND CRUSHER
        yes absolutly
        nine auto in my car :hitler:
          my last car was swapped from an auto e36.. it has a separate ecu that runs the trans... you will have extra wires that can be cleaned up. but its not a big deal.
          91 e30 318is M50 SOLD
          http://www.r3vlimited.com/board/showthread.php?t=149570
          92 325 vert project
          http://www.r3vlimited.com/board/showthread.php?t=341370
            Will I need to have the trans computer plugged in for the engine to start? or will the engine just crank without touching the trans wiring?
              Restoring this thread :)
                Just throw out the transmission DME and wire it up like normal.
                Originally posted by mbonanni
                I am a pursit now.
                  I've been searching around and a guy had a no crank concern and this is what he did:
                  "Problem: crank but no start
                  Solution: I had "drive-away protection" (pin 81 at the DME connector, pin 7 at the x20) connected to my e30 c101 "service indicator reset" (pin 11). This caused a no spark, no fuel situation. As soon as I cut pin 7 on my c101, it fired right up!
                  Also, in order to use the service indicator lights, I ran pin 11 on the c101 to pin 19 on the x20. Service lights fully function now!"
                    I got my engine from a auto car aswell. This was a main concern for me prior to doing my swap. However it turned out to not be a issue.
                    Do like stated above. Remove the transmission DME, and all associated wiring, and you shall have a running swap, with no issues.
