S52 Manifold Plug...size??
  • 1990m3
    • 1180
    I can't find for the life of me a bolt to plug the o2 sensor holes in the S52 manifolds I'm using. I think it's an M18 thread, but I dont' know what pitch the thread is. Anyone? Jason89i you know the answer?
    thanks in advance, what a pain this stupid little plug is to find...
    Dave
  • Jordan
    • 12916
    Use O2 sensors...
    https://mtechniqueabs.com/
    • 1990m3
      • 1180
      those are kind of expensive to use as plugs, especially since i don't have any old ones.
      • 325Projectz
        • Jan 2005
        • 1956
        Junkyard.
        91 m3
        • aaron_silva
          • 1785
          I can get the p/n for you later.
          Aaron
          • Jason89i
            • Sep 2004
            • 875
            Originally posted by 1990m3
            I can't find for the life of me a bolt to plug the o2 sensor holes in the S52 manifolds I'm using. Jason89i you know the answer?
            Dave
            i wasnt fond of sticking dummy o2 sensors there....oil drain plugs worked great. i got some new ones from the local parts store. i think (shooting from memory) they were 18x1.5. i added a washer so the threaded end didnt stick into the flow passage too far. looks just like aarons posted above. cheers, jason
            • Addissimo
              • Mar 2004
              • 1820
              yeah....
              Aaron-
              I think you need to post that part number, along with the part number for the hole between the cylinders on the flange.
              Thanks,
              Addis
              Doing something M50 related? -> http://www.addissimo.com
              On Myspace? ->http://groups.myspace.com/r3vlimited
              BF2142 SN = BillyGoose
              • 1990m3
                • 1180
                addissimo - it looks like aaron tapped that hole and threaded a bolt in there. That's actually a really good idea. Mine's already welded otherwise I'd do that tomorrow.
                aaron - I didn't even think of an oil pan drain plug, I have a spare on or maybe even two I'll have to try tomorrow, good idea. I couldn't find the part number on realoem.com for that plug. The pic shows a plug but it doesn't list a number for it. I tried a bunch of different cars and had little luck, please post it if you can find it.
                Dave
                • aaron_silva
                  • 1785
                  Okay guys. The p/n for the 02 sensor plug is: 11621437517
                  Dave is correct. I had the manifold tapped and a plug put in. Also, rumor has it that the one piece exhaust gasket (for 3 exhaust ports) is a better choice to go with over the individual gaskets. The p/n for those is 11621744252.
                  Here it is from the other side.
                  Aaron
                  • 325Projectz
                    • Jan 2005
                    • 1956
                    OT: Aaron, when did you start you project? Is it done?
                    91 m3
                    • Bryson
                      • 1490
                      Originally posted by Jordan
                      Use O2 sensors...
                      they don't clear some of the blocks...
                      • 1990m3
                        • 1180
                        thanks aaron, does that part number include the crush washer?
                        • aaron_silva
                          • 1785
                          Yes, I believe the plug came with the crush washer.
                          Aaron
                          • hugh jass
                            • 2220
                            I had a shop weld up the hole on the manifolds. It cost me $20.
                            ______________________
                            ex-Chief Operating Officer
                            Blunt Tech Industries
                            West Coast and Pacific Rim
                            • 1990m3
                              • 1180
                              I just ordered the two bolts from the dealer and they cost $6 each, washers included. I know it's expensive, but screw it, this is one of the last parts i'll be buying for a few weeks, this puppy should be running in a week or so...
