540 6 speed gearbox - can it work on a s50?
  • ARCH-E30
    • Nov 2009
    • 11
    Fallas, I found this 540 being parted out yesterday. I can score the gearbox and all associate parts for $300.00 has any one made this work on a S50 motor as I already have a complete motor & 5 speed for a swap. The 6 speed would be nice if it will work. This gearbox seem unique to the 540. I'm figuring I'd have to change the bell housing. any thoughts or guidance would be appreciated.
  • nrubenstein
    • 3148
    Sure. You have to cut off the bell housing and weld on a compatible one. There are only a few people in the country who can change the case, and they'd probably charge you for a full rebuild.
    Net-net, for $300 you should buy it and resell and roll that into a transmission that you can actually use.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Cyrix2k
      • 593
      this. You want a transmission from a BMW small 6.
      1997 540i/6 - stock
      1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
      1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
      • mtlbloodshot
        • Jul 2011
        • 761
        Good to know that there is an alternative instead of purchasing a S54 transmission. Ive read that a S54 is straight bolt on to a M/SX
        MY BUILD THREAD
        http://www.r3vlimited.com/board/showthread.php?t=235231
        INSTAGRAM : @luchcolaneri
        • FredK
          • 14761
          The better alternative would be a ZF 6 speed from an E90+ 6 cylinder car. It will bolt up to a M5x, S54, M42, and so on.
          I forgot to mention, it is available for around $650, not $1100 like an S54 transmission.
          • mtlbloodshot
            • Jul 2011
            • 761
            You FredK are a CHAMP! Thats the best news I've heard all day!
            MY BUILD THREAD
