Ok so I have put about 6000 miles on the swap and im still having over heating problems and the warmer weather isnt helping.
Ive gone through 2 water pumps and 3 thermostat and 2 radiators.
The first water pump started screaming after 2k miles. first 80 deg thermostats was bad then I replaced it with another 80deg.
Then I made a bleeder screw in the Thermostats housing and adding a 75deg thermostats.
I have a Pusher fan in the front.
The First Radiator was a brand new M42 radiator and Ive heard they sometimes cant cool the bigger S52s so I snagged a used M20 radiator thats in ok condition but isnt clogged or leaking.
Just ran a compression test to check HG
190 195 190 190 200 185
All the number seem good.
So the car temp stays at 1/4 when on the freeway and as soon as I slow down it jumps to 1/2 then if stopped or slowly moving in high rpms it starts creeping up but if i start moving again it drops back down. Also if I turn the heater on I can manage it a bit. Im 95% sure the air is bleed b/c of the bleeder valve.
But all being said everything is new except radiator but seem to be fine SO I really dont know what to do now. Car should running around 1/4 with the 75deg tstat.
