Had a customer back out of a harness order. Already have most the parts needed to complete and want to offer it up here before I start piecing it out for other projects. Specs are as follows:
Plug & Play M/S5x to e30 swap harness, ecu to c101 full harness, not a adapter. 100% new parts.
All new connectors and pins, including bosch 88 pin ecu connector.
Mil spec wire (M22759/32)
Expando FR+ sleeving (most companies i.e. rywire/chasebays use expando xt, I use FR+ because it takes higher temps)
Cost is right about $600
Would prefer someone in chicagoland area for vehicle access. But can do it blind if provided your M/S5x harness for mock-up. Harness will not be damaged in any way, and returned to you.
P.S. Is it still possible to buy new c101 connectors? I can get the pins all day, but been some years since I bought the actual connector.
