My M50NV swapped E30 LeMons car had been running perfectly fine up until now. Out of the blue this morning, when I started up my car it had a major backfire through the intake. The smoke was bad enough that I thought I something caught on fire. I shut it off and couldn't see anything amiss, so I fired it up again and it runs, but barely. It's backfiring/popping through the intake at idle, and will only run for a few seconds. When I crack open the throttle, it sounds fine, but the engine revs more than I'm actually opening the throttle. In other words, if I open it 1/4 way, it sounds like I'm going WOT for a second, then drops down. Here's a video:
Yesterday I swapped in new spark plugs and a new MAF boot (mainly because I had to change the brake master cylinder and I had no idea how old the boot was, so it was cheap insurance). Those are the only changes I had made recently, and after I did those things, the car fired up and ran perfectly. The car has fuel and fuel pressure (have a gauge at the fuel rail inlet), and when I pulled the plugs they were already fouled black and smelled like fuel. The car has always run a bit rich, but the car had literally only run for about 10 seconds yesterday, so I don't know why they'd be so soaked. I swapped in a spare MAF and DME separately and neither helped.
Intake backfires like that are typically caused by a lean condition (definitely not the case here) or incorrect timing. I hadn't done anything near the crank position sensor lately, but is it possible the sensor has crapped the bed all of a sudden?
Any help is greatly appreciated. I essentially have a week to get this fixed before a race.
