Why e21 trany mounts?
  • 02stu
    • Jan 2005
    • 872
    It been a while since I've done any work on my swap and its about time to get back into it. So whats the story on e21 tany mounts; are they stiffer, or do they have different dimensions? Also does anyone know if 318is' uses different trany mounts then 325i's? Thanks
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    Bump: I'm also curious about this question. I see that e21 tranny mounts are recommended but i dont see why. Don't see why e30 moutns cant be reused
    • FredK
      • 14764
      The E21 trans mounts are way larger in diameter than the E30 trans mounts, and they are cylindrical. The E30 trans mounts are hourglass shaped and are more susceptible to flexing when the car is side loaded. This is also true of the E36 trans mounts, and is one of the reasons why people moneyshift E36s.
      • 02stu
        • Jan 2005
        • 872
        Thanks
        • arsevader
          • May 2005
          • 1025
          I think only the 4 bangers have 'hourglass' shaped mounts. The M20 uses straight mounts. Though the older mounts are beefier.
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            I will upgrade when i get a chance, for the the e30 mounts will have to suffice
            • japspecvr6
              • Apr 2005
              • 602
              is this the reason why my bottom gears are popping out....
              M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
              • matt
                • 3732
                e36 tranny mounts are hourglass shaped for sure.
