Got the motor running (NEED HELP)
  • Widebody325
    • 417
    Well I got the fuel pump problem sorted out. The motor will turn over and run for about 5 seconds, then die out. Has any one had this problem? And is there anything I should double check to figure out why it wont stay running? Thanks, Ben
    Follow me @baysidefabrication on Instagram
  • rs4pro3
    • 5808
    check to make sure proper pressure is getting to the fuel, rail, if so then pull the rail with the injectors, and have a friend crank the car while you watch the spray pattern, sounds like you may have some clogged injectors.
    85 325e 2.7 ITB'd stroker
    • pussy
      • Aug 2005
      • 34
      could be a air-leak, check your hoses..
      regards.
      • Jason89i
        • Sep 2004
        • 875
        check on the fuse to the pump that you are getting power while the car is running. i have seen A LOT of problems with fuel pump / o2 relays with these conversions.
        you might be getting fuel pressure while in the start position (builds up enough pressure to fire) but not in the run position (uses up left over pressure until it slowly dies.)
        cheers, jason
        • Skafrog
          • 1730
          what motor is this, and what DME do you have?
          NASA MidSouth TT Director / GTS2 #018
          Mods: Coastal PS Fluid, 10w40 Oil
          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
