Or it will it lock up? I need to get my '91 aligned and it currently has the p/s pump installed without any lines attached. Does the pulley spin on sealed bearings or does it use the p/s fluid to lubricate the whole pump?
Can the P/S pump be run without fluid?
Originally posted by willworkfore30s View PostIt will burn it up, remove the belt to the pump. I'm not sure about an m20 but on an m42 there is a belt just for the p/s pump.1997 540i/6 - stock
1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
Originally posted by Exodus_2pt0 View PostIt will turn into an idler real quick, then once the fluid dries up from heat, it will fall apart.1997 540i/6 - stock
Originally posted by hooken m View Postjust remove it anyways and get a shorter belt. do it right1997 540i/6 - stock
