The OFFICIAL 24v Engine Bay Thread
This is a sticky topic.
  • tjhartge
    • Jun 2004
    • 86
    #91
    Originally posted by Tom944
    Just a mocal cooler installed where normally the passengerside headlight would be. Not going to modify the engine, instead we use this oilfilterhousing cap :
    cool setup Tom.....
    so which oil cooler lines and oil cooler housing will you be using ?
    does that mocal kit include the lines?
    another question about oile pressure control and buildup, isn't there suppose to be a oil temp switch or something?
    i read sometime back, it will take sometime for the engine to warmup if there wasn't a oil temp/pressure control valve
    • ed chitwood
      • Nov 2004
      • 59
      #92
      88' m3 obdI s52
      engine 99' M3 84k miles
      getrag 260 w/ custom flywheel, M5 clutch and pressure plate
      95 m3 harness, ecu Intake setup
      Mods;
      Active Autowerke software
      21.5 injectors
      540 HFM
      BMP adjustable fuel pressure regulator
      custom 3.5" CAI w/heatshield
      full length headers
      no cats, AA catback
      UUC power pulleys and short shift kit
      clutch fan delete
      H&R RSS Club Sport Coilovers
      Ground Control camber plates
      Eyeball control arm bushings
      IE 25mm front & 22mm rear swaybars
      Adjustable rear trailing arms w/urethane bushings
      Urethane subframe mounts
      E36 m3 front brakes w/cross drilled rotors
      M5 guibo
      410LSD
      Upcomming mods;
      Shrick cams
      Samco intake boot
      Big bore throttle body
      m coupe trailing arms
      95' M3 steering rack
      possibly a 391LSD
      "So you're saying there's a chance"
      • Tom944
        • Dec 2005
        • 150
        #93
        Originally posted by tjhartge
        cool setup Tom.....
        We are going to use a mocal indeed with home made lines. You can add a thermostate to the oilcooler circuit but we will have to test and see if it's needed.
        E30 Euro-S50B30 Tracktoy
        E30 M20B25 Drifttoy
        • Rev Engineer
          • Jan 2006
          • 162
          #94
          Time to post mine... More high-res photos can be found here: http://www.cityofdust.com/s50/
          • static
            • Oct 2005
            • 501
            #95
            ^^ nice bay
            noticed a lot of you guys have the air filter right near the rad and coolant hoses. I have it the same way and notice quite a bit of reduction in power when it gets warm under the hood.
            Anyone noticed that too? There is close to no space to be able to organize some kind of a cold air box/shield (damn ABS is on the way)
            Also i hear having air filter sitting right on the HFM is a not so good idea, as air coming right out of the filter is very turbulent and doesn't get measured correctly by the HFM
            • Rev Engineer
              • Jan 2006
              • 162
              #96
              Originally posted by static
              ^^ nice bay
              Thanks for the info! I'm not done with my air intake, but it's going to just sit there for now until I figure out something better to do.
              • DeM3n
                • Mar 2005
                • 1260
                #97
                ^^ nice bay
                I have a set up that I am running (currently, for the summer) that is quite helpful.
                The fiberglass looks kinda crappy on the outside but is smooth on the inside. This was my first attempt working w/fiberglass but am planning on making a better looking one for next summer. I definately got a better throaty sound and a little bit extra "umph" out of this. Entire thing cost less than $30. Definately worth it.
                • KangamangusDriver
                  • Aug 2005
                  • 1870
                  #98
                  I like the design idea, however how does that do in the rain?
                  Cant imagine its too good for your maf or engine
                  • Tom944
                    • Dec 2005
                    • 150
                    #99
                    Enginebay almost finished. Only the oilcooler will be added, as well as some hoodpins :
                    E30 M20B25 Drifttoy
                    • DEV0 E30
                      • Oct 2004
                      • 8851
                      #100
                      Where is your coolant resivour?
                      And what intake are you guys using?
                      • Tom944
                        • Dec 2005
                        • 150
                        #101
                        The coolingreservoir is part of the radiator, on the pictures you see the cap on the right.
                        The intake from the maf is a silicon hose with a greenfilter behind the headlight gril.
                        E30 M20B25 Drifttoy
                        • 1990m3
                          • 1180
                          #102
                          wow, nice install Tom944, that looks fantastic!
                          • Rev Engineer
                            • Jan 2006
                            • 162
                            #103
                            What's the radiator and overflow tank from?
                            • Tom944
                              • Dec 2005
                              • 150
                              #104
                              Thnx man :up:
                              From ebay. It's an e36 325i look a like type rad and as said, the tank is part of the radiator.
                              E30 M20B25 Drifttoy
                              • 1990m3
                                • 1180
                                #105
                                I don't think so, I think that's a 318 radiator. I have a 318 radiator sitting in my shop and a 325 in my car, the 325 radiator is a lot bigger. You were sold the wrong part I think. A few people here are running that radiator because of the convenient overflow tank, but in a racing or hot weather application I don't think that smaller radiator would work quite as well.
                                The 325 radiator is almost identical to the e30 325 radiator and it's as wide as that radiator and coolant bottle combined. Check out the other engine bay pics in this thread.
