Ok before I go blowing stuff up I’d like some feedback to ensure I have everything hooked up correctly. First a couple “basics”…
Chassis: ’89 325is (originally auto, swapping to G260 manual)
Engine: S50 - ’95 M3 (9/’95 build)
Harness: S50 - ’95 M3 (9/’95 build) AUTO harness
Tranny: G260
Flywheel: Lightened single mass G260
Starter: G260 (duh…)
So I did all wiring (fingers crossed) and was left with the following:
Passenger Side:
- A – RED/Delete(?)/Goes to E36 harness/SPLITS into two red wires on driver’s side near fuse box– Thought to be E36 fusebox power and starter wire. Will delete as I’m using the E30 starter wire and retaining E30 fusebox power lines.
- B – RED/Power Block(?)/Goes into E36 harness/Unsure of termination point
- C – BROWN/Strut tower ground/Goes into E36 harness/Terminates with other brown grounds
- D – UNKNOWN/From Power distribution block/Goes straight to large post on starter
Alternator (not shown)
- E – (NOT SHOWN) RED/Goes from large post on Starter (stacked with D) to the alternator large post
- F (NOT SHOWN) UNKNOWN color/Goes from small post on alternator to the harness – think this is the signal wire to the alternator?
Driver Side:
- G – RED/Starts at A above/ Would usually go to fusebox for power on E36’s. Will be deleted for the swap in favor of E30 wiring?
- H – RED/Starts at A above/Would usually go to the large post on the starer in E36’s. Will be deleted for the swap in favor of E30 wiring?
Tranny: G260
Passenger Side:
Driver Side:
