E30 S50 Swap Oil pan question.
  • Munich Man
    • Jan 2011
    • 516
    Ok, so I'm not a total noob, I know you need E34 oil pan which I just got about an hour ago. My question is; How much lower does an S50 with an E34 oil pan sit compared to stock M20? Because right now my car is really fricken low, and my pan hits at least 3 times I go anywhere. Please someone tell me there is a way that isn't too redneck to keep the S50 with E34 oil pan up higher.
  • Nick_S
    • Apr 2011
    • 3658
    Add a few spacers to your engine mounts? Or raise your car up? Or get a skid plate? Or all three.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • Munich Man
      • Jan 2011
      • 516
      I don't want to rais the car up, looks good the way it is. Spacers; maybe. What I am really curious about is how high it'll sit aftert the swap. Lower, or higher than stock.
      • berlow94
        • Jan 2013
        • 1063
        Raising your engine up effects how high your center of gravity is by a little. Raising the whole car will effect it more but regardless of looks. I would never drive a 24v swap without a skid plate. Oil pan sits way too far below the front subframe.
        The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
        • Munich Man
          • Jan 2011
          • 516
          Ok, question answered: Oil pan sits lower than stock after swap. Thank you!
          • e30austin
            • 15382
            It sits about the same as an E30 M42 pan, give or take a little.
            • bonobo
              • Jul 2012
              • 94
              I'd be wary of spacing the engine up too far, you don't want to fuck with your driveshaft angles. I think someone on here had a swap pan custom welded, maybe you could look into that.
              1988 BMW 325 - S50B30US
              Instagram "Build Thread" - http://instagram.com/jfchiu
              • 36brua
                • 689
                Something like this ?
                My CA legal M60 swap
                The happening in our garage
                • /\/\ III
                  • Nov 2007
                  • 80
                  just throwing this out...but would a dry sump work? flat oil pan.
                  • 36brua
                    • 689
                    See post 50 for phtos
                    • Munich Man
                      • Jan 2011
                      • 516
                      Originally posted by 36brua
                      Looks so bad ass and quality; but $650 I just can't do it haha.
                      • 36brua
                        • 689
                        Thats OK.. neither can I:)
                        • Roysneon
                          • 4505
                          That's a bit overkill for a US S50 in a street car.
                          OP to answer your question, it hangs pretty low but on my M50 car with H&R race and 15mm drop hats I never broke an oil pan, even when driving on 14" wheels with undersized tires in the winter. The roads where I live are not good at all and I drove the car through New England/NH/NY/NJ area and the streets there are FUCKED, yet I made it through OK. Just get a skid plate and drive smart, you won't have to worry much about broken pans.
                          Originally posted by mbonanni
                          I am a pursit now.
                          • NickL
                            • 562
                            Just shim the mounts. The 24v pans hang lower. My pans even with the subframe and i have no driveshaft issues, no vibration etc. Probably will prematurely wear the guibo but I'm not worried about it.
                            1987 325is - S52
                            • Jim Lepage
                              • Jul 2008
                              • 1138
                              Did you shim the transmission mounts too ?
                              E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
