Couple issues with S50 car.
  • Danny
    • 14216
    Okay so two issues with my car right now. My unloader relays do not work. I currently have k5 and k7 jumpered with a wire to get the windows and aux fan/blower motor to work. Problem is they are constantly hot. The battery will drain. I saw a post by Nando that I can ground pin 15 of the c101 to bypass the unloader relays. He won't answer my PM. Can anyone else verify?
    Second issue is the car has absolutely no midrange. Engine has no feel of a misfire. Also idles very well. It pulls smoothly but with a distinct lack of power in the mid range. I have had the VANOS unit replaced with a Dr. Vanos unit by RyanGMW. Still have no midrange. the car is gutless until about 4500 rpms. I'm leaning toward VANOS solenoid but I have no check engine light. Kyle (Surebimmer) suggested replacing coils. Thoughts?
  • berlow94
    • Jan 2013
    • 1063
    If you are getting power after 4500 then my guess would be that VANOS is working. As to why there is no power before then? I would go through it all. plugs, coils, check intake, vacum, blah blah blah.
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • Danny
      • 14216
      The following parts are all new:
      Plugs
      Vacuum system resealed (intake manifold gaskets, all vacuum lines and connectors, throttle body gasket, PVC system.)
      Crank sensor
      O2 sensor
      Cam sensor
      Tps
      Vanos unit
      Fuel pump
      Fuel filter
      • 328ijunkie
        • May 2007
        • 3961
        Vanos solenoid/wiring/timing causes exactly that
        Check Us out on Facebook
        Full Product Line Tuning
        • Danny
          • 14216
          Have you ever seen a vanos solenoid go bad? Also any insight on the unloader relay issue?
          • Jean
            • 18228
            Hmm, my m50v is pretty gutless as well, until 3-4k... always been like this since I bought the car. Keep us posted Danny if, but the vanos unit was replaced wasn't there a way to check the vanos with gt1 or whatnot that it's working?
            • giantkeeper
              • Aug 2009
              • 1416
              Vanos solenoids can go bad. Pull it out and clean it up. IIRC you can also test the single vanos solenoids.
              Always Always go for the reach around if there is an option
              • M-technik-3
                • 18946
                It's common for it to fail above 125K mile range. They are cheap and easy to replace.
                • Danny
                  • 14216
                  Yeah I have a gt1 at work I can at with. Planning on hooking it up tomorrow.
                  Any idea on how to test?
                  Cheap is relative. ;) thanks for all the help guys. Anyone have ideas on the unloader issue?
                  • giantkeeper
                    • Aug 2009
                    • 1416
                    • Jean
                      • 18228
                      Says not a typical failure...
                      (US Single Vanos Solenoids only) It's very rare that a vanos solenoid needs to be replaced. Typically the wire lead becomes damaged and breaks or shorts out, but the solenoids are otherwise very durable.
                      How to test your solenoid: Unplug the wire lead at the back of the solenoid from the main wiring harness first. Remove the solenoid from the vanos unit with a 32mm wrench, and jump the connector to a 12v power source and ground. Note that there is a + and - marking on the connector. Be SURE to connect the leads properly or you may damage the solenoid. The pin inside the solenoid should 'pop' out approximately 5mm. If not, the solenoid needs to be replaced.
                      • giantkeeper
                        • Aug 2009
                        • 1416
                        Yessir, every s50 car I've ever seen has that beat to shit wire.
                        • Danny
                          • 14216
                          Any insight on the unloader issue?
                          • 328ijunkie
                            • May 2007
                            • 3961
                            C101/Starter Wiring...
                            • Bimmerman325i
                              • 6854
                              Danny, this will sound retarded but I managed to do it.
                              Does your car show low oil pressure light on startup/key on?
                              It is SUPER easy to switch vanos plug with oil pressure plug, and then you get no midrange, no CEL, and no misfires, along with no low oil pressure warning light at startup/cluster illumination on ignition.
                              Though I'm not sure E30 cluster will behave the same, it's been a while. Try swapping the two, it won't hurt the car, and see if that solves the issue.
                              2017 Chevrolet SS, 6MT
                              95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                              98 M3/4/5 (stock)
