Is it better to go with the stock e30 power steering hoses or with the e36? With the e36 hoses I can mount the power steering reservoir onto the oil filter housing right? And the e30 hoses it mounts up to the motor mount arm. Which one is better to run with?
m52 power steering lines
If you're not going to do it right, please don't take it out on your car!Tags: None -
with the e36 hoses it mounts on the engine mount arm.
I wanted to use the e30 ones and have it mounted up high so it's easily accessible but there's no room for it. at least with using the ix or 7 series booster. otherwise in performance or durability there's no difference. -
I have the e21 booster so would that leave enough room for the e30 hoses?If you're not going to do it right, please don't take it out on your car!Comment
No I don't have cruise. I guess I'll give the stock hoses a shot and see where I'm able to mount it up atIf you're not going to do it right, please don't take it out on your car!Comment
