E30 M50B25 problem *SOLVED*
    Hello guys! At first I'd like you to know that im from Finland and my english might not be as good as your's but i hope that you would understand something.
    The problem is this : http://www.youtube.com/watch?v=Wep3-1lM--M
    You can hear the rpm's humping or something like that.
    The previus owner had put the fuel tank and pump in to the trunk.
    Things I have checked/repaired/changed:
    New Bosch Lambda
    MAF that has been taken from a working car
    NGK BKR6EK Spark plugs
    Vacuum hoses etc.
    Ignition coils
    Crankshaft position sensor
    Intake manifold gaskets
    Fuel filter
    I'm running out of ideas what might be causing this problem.
    Unplug your MAF: PROFIT.
      I have tried it several times with both, the new and the old MAF. Engine starts running worse than in the video.
      I opened the Motronic box and found out that there was some corrosion on the electric parts.
      I tried to clean it and let it dry for over night and today I'm going to try if it worked.
      Edit: It worked!! I cleaned the motronic electronics from the corrosion and it works!
