shift link question
  • rede30
    • 4697
    shift link question
    How to i get the shift linkage off of the tranny
  • 86325e
    • 228
    You need to try and remove the bitch clip or break it off. Thats the clip you see in the second photo. It's called a bitch clip for a reason. I recall Jordan saying that he made a special tool to remove it. I ended up using a long pry bar and a hammer to break mine off and just installed a new one after I was done changing all the bushings.
    Eric
    85 325e M50 and auto to manual transmission conversion...
    • Addissimo
      • Mar 2004
      • 1820
      make sure its rotated correctly-
      I have one of those S shaped screwdrivers that I pair up with a hammer- it works great.
      Doing something M50 related? -> http://www.addissimo.com
      On Myspace? ->http://groups.myspace.com/r3vlimited
      BF2142 SN = BillyGoose
      • FredK
        • 14761
        Hahaah it is called the bitch clip, but MAGICALLY mine wasn't that bad to remove. I used a regular screwdriver and bent it up.
        Ron Stygar has a writeup on how to remove it. If you understand how it's installed, it sort of helps you visualize how you need to push up on it, and where to push up on it. Good luck!
        I removed it from underneath the car actually. I guess I got the perfectly sized screwdriver for the task...
