Vanos Tool Drawings
  • AndrewBird
    The Mad Scientist
    • 11892
    Vanos Tool Drawings
    I recently rented the tools to replace the vanos seals on my M50 TU. Before I mailed them back, I measure all of them and created some drawings to re-make them. Thought some of you might be interested.
    Right click -----> Save as.
    I originally drew them in metric, but then converted everything to inches, so all the numbers are nominal metric numbers, despite the drawings being in inches.
  • psigti
    • Sep 2012
    • 290
    I've never had to mess with my vanos...but you sir are brilliant. Thanks for sharing this info.
    Sent from my SCH-I535 using Tapatalk 2
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      From your knowledgeable standpoint, with those drawings, would it be cheaper to have a machinist make the components, or buy the set?
      • pilotskillse30
        • Dec 2006
        • 1957
        thanks
        • poopin04
          • Jul 2010
          • 1396
          3D printing!!
          Click here to leave me feedback on our transactions. :p
          • AndrewBird
            The Mad Scientist
            • 11892
            How much is the set to buy?
            • dude8383
              • Jan 2005
              • 10387
              Good question... I paid like $120 or so for the Baum Tools.
              • AndrewBird
                The Mad Scientist
                • 11892
                For that price, it's likely cheaper to just buy them than have them made. If you can make then yourself though, all the better. That's what I plan to do.
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  Nice to have drawings!
                  • AndrewBird
                    The Mad Scientist
                    • 11892
                    Just a note, the "Cam Lock Blocks" as I called them are identical except for the one missing chamfer on one of the "towers" and the threaded hole in the bottom. Also, I didn't put a depth on that threaded hole. Just make it deep enough to thread a bolt into a decent ways.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      Nice CAD drawings
                      Check Us out on Facebook
                      Full Product Line Tuning
                      • AndrewBird
                        The Mad Scientist
                        • 11892
                        Thanks. I used to work as a drafter, so I know quite a bit.
                        • /\/\ III
                          • Nov 2007
                          • 80
                          very nice, i was just thinking abou this, the price to buy is way too much, i am going to price it from a machinist
                          • SkiFree
                            • Jun 2011
                            • 2766
                            If you think that price is high, then I hope you have a real friendly machinist/cnc guy.
                            We had a bunch made here, but at the same time they were finished a bunch of chinese ones showed up the same time on ebay.
                            ADAMS Autosport
                            • Wanganstyle
                              • 2828
                              nice drawing !!
                              my local machine shop would probably get that made for me the same day I ordered.......cost would likely be about $350-400 though LOL. Thanks to bay area machine labor @ $100/hour.
                              camblock full set made in china was only $120 or so with the vanos movement tool and pin.
