M52 cut out
  • mtlbloodshot
    • Jul 2011
    • 761
    M52 cut out
    So, Im odb1 M52 with S52 CAMS, 21.5 lb injectors and other add ons. I got the TRM tune customized for what I'm running but when I give full throttle, it seems like I reach the limiter and it just redlines at 6.
    I questioned maybe it was the fuel pump but the engine does not starve for fuel, it simple just reaches the limiter. Could it have to be something with the chip or something with ECU?
    MY BUILD THREAD
    http://www.r3vlimited.com/board/showthread.php?t=235231
    INSTAGRAM : @luchcolaneri
  • 328ijunkie
    • May 2007
    • 3961
    Vss
    Check Us out on Facebook
    Full Product Line Tuning
    • mtlbloodshot
      • Jul 2011
      • 761
      Originally posted by 328ijunkie
      Vss
      what is the remedy for this problem?
      MY BUILD THREAD
      • luckysnafu
        • Jun 2008
        • 262
        Remedy is here - http://www.r3vlimited.com/board/showthread.php?t=285584
        Why are so many people having problems with this? I feel like this comes up a few times a month.
        M/S52 Wiring Diagrams
        Z3M S52 to late model 325i wiring diagram
        M52 to 318is wiring diagram
        • mtlbloodshot
          • Jul 2011
          • 761
          What if I change my VSS in the diff?
          MY BUILD THREAD
          • dsobering47
            • Oct 2007
            • 697
            WTF is going on here. The DME doesnt see vehicle speed and sets a soft rev limit at 6000 rpm? I've driven my car, but not to redline (not that my tach works anyways) but why would vehicle speed affect the DME setting a lower rev limit?
            • 328ijunkie
              • May 2007
              • 3961
              Why would any other sensor? It doesn't know how fast you're going. So it can't govern you at 128 or whatever so they did some math to see what rpm that would be. So 5500 it is.
              • mtlbloodshot
                • Jul 2011
                • 761
                So the VSS in the diff should fix this problem?
                MY BUILD THREAD
                • e30rapidic
                  • 2167
                  have you searched any? VSS signal has been covered in here a billion and two times. My dme gets a signal from the cluster
                  '87 325ic, powered by S50.
                  • mtlbloodshot
                    • Jul 2011
                    • 761
                    If you have to post just to post with no real response or help. Don't post
                    MY BUILD THREAD
                    • amcink
                      • 788
                      Subscribed
                      • luckysnafu
                        • Jun 2008
                        • 262
                        Did you not read through the thread I pointed you to? It tells you exactly what you need to do:
                        Connect pin 9 of the X20 to pin 14 of the C101
                        Once that is connected you won't have any problems with rev limiting.
                        • mtlbloodshot
                          • Jul 2011
                          • 761
                          http://www.r3vlimited.com/board/show...8&postcount=30
                          I connected that already when I did my harness. Is it possible that my VSS in the diff has gone bananas?
                          MY BUILD THREAD
                          • e30rapidic
                            • 2167
                            My VSS works perfectly...and all I had to do is search on this forum.
