M50tu Idle/Throttle Response Problems
  • grc
    • Dec 2010
    • 22
    R3v, I need your help...
    I have an 89 325i with an m50tu swap. It has trouble finding idle and the throttle response is terrible.
    I'm not sure if it would be possible to diagnose the problem through a video, but it can't be worse than trying to describe it in words. So, here it is:
    The first time I cranked it (after sitting for more than a year) it started to leak from around the fuel filter area.
    Could that be related to the idle issues?
    Thanks in advance :oops:
  • !kid
    • 1362
    Give the ICV a good cleaning. the valve on the inside should move smoothly.check the condition of all your vacuum hoses as well.
    :borg:
    • grc
      • Dec 2010
      • 22
      Oh, I forgot to mention that the ICV is brand new.
      Im gonna try to do a hookah smoke test tomorrow and see if I find any vacuum leaks
      • maclogos
        • Jun 2013
        • 120
        Could a bad TPS cause this?
        • 328ijunkie
          • May 2007
          • 3961
          Rather large Vac leak.
          Check Us out on Facebook
          Full Product Line Tuning
          • pmat
            • Nov 2012
            • 174
            Is your breather blocked off with a bolt??
            318is, m50tu g240 s3.46
