dont bash need help wiring my adapter
  • BrandonG
    • 232
    hi im doing a m50 swap in my 86 eta , i cant find a clear diagram this is my first time doing an m50 swap i have only done b25 swaps in the past , if anyone can point me in the right direction id greatly apreciate it, i also read the tach signal and mpg signal is somewhere under the dash , i already tucked my headlight harness and shaved my bay i just need to finish my engine harness :)
    DO WORK
  • Joseph93
    • Jul 2013
    • 21
    ETM's are your friend click me!
    • BrandonG
      • 232
      I'm looking for more of a clear diy , I found some for a late model but cant strike gold for my early model
      DO WORK
      • M-technik-3
        • 18946
        86 Eta's are crossover model so it is determined by early or late model.
        • BrandonG
          • 232
          She be an early model smaller taillights in rear
          DO WORK
          • 328ijunkie
            • May 2007
            • 3961
            You're gonna have to do some digging. I haven't seen a early
            Model one in a while.
            Check Us out on Facebook
            Full Product Line Tuning
            • BrandonG
              • 232
              Damn thers gotta be one somewhere
              DO WORK
              • burlmays9
                • 227
                E34 or E36 harness? I have a pinout for a '86 325es to E34 NV harness that I made up when I did my swap.
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  Etm? ;)
                  It's one thing if you need help on a few pins, but when I had to wire my swap it was: post your chart and we'll give it a looksy so you dont fry your harness.
                  I think the same principals are alive today.
                  Originally posted by 325Projectz
                  don't listen to the diagram... listen to mr. swiss.
                  :nice:
                  • BrandonG
                    • 232
                    I believe its an obd1 e34 harness , I fried a harness before doing a m20b25 swap big face palm that's why I'm asking for help to play it safe :)
                    DO WORK
                    • brent5631
                      • Jun 2012
                      • 421
                      a lot is the same between all years just minor differences. Look up the pinouts from the swap wiki and what you can find here. then fo through the etms yourself and make your own then compare.
                      • M-technik-3
                        • 18946
                        Never mind was gonna make a comment. But I'll keep it to myself.
                        • RobertK
                          Kicked cancer's ASS.
                          • Jun 2005
                          • 5864
                          1. What is the build date of your car?
                          2. What is the build date of the E34 your harness came from?
                          • BrandonG
                            • 232
                            Haven't been on in a while due to busting oil pan on my vr6 but I'm back at work on e30 I found 3 schematics that point me in direction i have an e34 obd1 5spd engine harness I think I got this figured out now
                            Sent from my iPhone using Tapatalk - now Free
                            DO WORK
