I just completed my m50 swap and took it out for a spin when it had a couple heat cycles just to make sure everything was settled and working. It idles goodish, my old m20 had a vacuum leak and was slightly down on compression so i havent had a good idling car to compare. It wanders maybe a 100rpm or so and air fuel ratios wander from 13.8 to 16 when hot, not sure if they should. When i drove it, it felt almost the same as my 200k m20... felt really slow in lower rpm and picked up eventually, but not any harder than my m20 did.
I checked for vacuum leaks, intake booot was torn up so i temp fixed it with tape and there doesnt seem to be any large or even medium leaks, maybe small.
I checked for weak spark and it was not exactly strong, so i double grounded all my coils. Id say it improved slightly but not enough for me to stop thinking.
I did however notice that when i unplug the maf, idle doesnt really change that much, and it revs up exactly the same... this confused me. Although i didnt drive it with the maf unpluged, it didnt seem to do much.
Any suggestions on what to check?
M50nv, gearing stayed exactly the same, same tranny and diff, so no its not gearing. New plugs too.
Pic for people who cant contribute, just so im not wasting your time, people love pics...
