Hey all,
So i have a 1989 325i with a M50TU swap. Specs are G260 trans (custom trans mount) with stock M20 shaved flywheel and stock clutch. The issue im having is i hear my engine making a ticking noise when i rev. At idle there is no ticking. Could this possibly be signs of a bad lifter? I also noticed that when the car is cold and i try to punch it a bit thru gear the driveline will make a slight clunking sound. I replaced the diff already and also replaced the flex disc. Could the CSB cause this noise and not give any vibration to the cabin of the vehicle? Thats the one thing i havnt replaced yet.
Thanks in advance!!
Thanks in advance!!
