m52tu28 Camshaft options
  • jwiles
    • Jun 2012
    • 200
    I'm getting ready to come across a great deal on engine Hopefully it will be free or the max being an added $100. (motor has bad head gasket, and ive given him an auto tranny, drive shaft, and $100 worth of break fluid
    originally i planned on getting an s52 but this popped and theirs only a 50 hp difference, im not really going to go on about stroking the horses face with adding performance.
    i looking for Camshaft options for the m52tu28.
    i wanted to do the Schrick cams originally and stage 3+ tuner package.
    Schrick performance camshafts (264/256 degree
    but i could be content with the stock s52 cams.
    i need to out run a 2000 is 325i
    ive even heard that m54 cams will work but i dont know the performance gains that are possible with these cams and if they really do fit.
    Last edited by jwiles; 09-19-2013, 11:50 AM. Reason: i need to out run a 2000 is 325i
    hell idk sometimes you just have to wing it. JW
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    ZHP cams, but really the best thing to do would be to just get an M54b30 to start with as you would give you more power gain then cams.
    • jwiles
      • Jun 2012
      • 200
      Why should I go with the m54 cams?
      • Thujalvi
        • Oct 2012
        • 72
        You shouldn't, unless you're talking about the ZHP cams mentioned, as M52TU and M54 use the same cams, on this side of the Atlantic at least.
        '93 Daytonaviolett Touring Design Edition
        • Coyote_ar
          • Sep 2009
          • 175
          you will get more performance by switching your intake manifold to the one from the M54, than from a cam. That intake manifold doesnt flow as well as the M54 does.
          Its a similar thing as with the M50vsM52 manifold from the old iron blocks.
          Once you have that, and a nice exhaust manifold aswell, yeah maybe you can start talking cams (and valvesprings if you intend to go over 7000rpm).
          ---E30 320i Hennarot 1984 Sedan---
          • DesertBMW
            • Aug 2011
            • 1042
            M54b30 intake cam is hotter, just go with this. Or ZHP cams(hard to find now), Don't go schrick on 2.8L they are too aggressive
