M50 overheating still..
  • OneCleanE30
    • Jan 2013
    • 213
    So I have an M50 swapped E30, I replaced the T-stat and replaced the water pump... Still over heats. I'm getting seriously annoyed and its my daily driver. Please help me. The heat blows cool even when it over heats..
  • AlexHale
    • Nov 2012
    • 230
    Have you bleed the coolant I'm assuming?
    Originally Posted by Exodus
    He also kept asking why someone local didn't just go to the guys house and break his kneecaps, as they would do in Romania. He couldn't understand how us Americans are so laid back about shit like this.
    • travis816
      • 828
      What radiator? What combo? thermostat? Give some more info here... fan?
      88' m3
      91' 318is
      • knuklehead92
        • Aug 2011
        • 732
        for m50 you have to jack the car up and rev to let the bubbles out. also if havent drilled a hole in the t stat its easier to bleed. make sure the t guage is reading properly. if it bounces means the ground isnt securely connected in the back.
        Trust me it stock :yawn:
        • E30NJ
          • Aug 2013
          • 921
          look for any clogged lines. make sure the upper radiator hose is hot and pressurized. If not, there is probably a leak.
