E30 CSB with E36 driveshaft
  • 36brua
    • 689
    Ok I've search and am getting 2 answers
    I have ZF320trans and the E36 4 bolt d'shaft
    Which way does the CSB get installed ?
    The E36 325i driveshaft with an E30 center support bearing mounted backwards
    or
    stock orientation ??
    THANKS !
    My CA legal M60 swap
    The happening in our garage
  • dude8383
    • Jan 2005
    • 10387
    Yes, you have to flip it.
    • 36brua
      • 689
      Thanks again to R3V !!
      • orangechicken
        • Aug 2014
        • 23
        I'm posting a variation of this question on several threads, so pardon if you've seen this already:
        Is this still the case if it's the offset-style CSB carrier on later E30 models? (And using an M3 driveshaft, not a 325i's?)
        • Habla
          • May 2004
          • 1470
          Just like it is installed on the e30 driveshaft. This means that you don't change the orientation of the CSB, you just simply install it on the back half of the e36 driveshaft. It isn't flipped or anything.
          -Peter
          318is slicktop | F15 35dM | F250 SD
          • M3PO
            • May 2012
            • 537
            I used a late model 325E/ES driveshaft and installed the bearing the same way the old one was (ie not backwards).
            • orangechicken
              • Aug 2014
              • 23
              In the process of this: Do you have to use the backing plate and cover plate for the E36 then? I bought the E30 kit from Pelican Parts but the plates that came with it won't work on an E36 driveshaft (with the CSB in the correct orientation).
              So... leave them off or will the plates from the E36 (as seen in this pic) work?
              • MyE30
                • Sep 2013
                • 326
                if you're using the appropriate e36 driveshaft, the e36 plates will work.
                • 36brua
                  • 689
                  from your pic -I reused both dust covers. one set from an 86 and one set from an 89 on e36m3 4 bolt driveshafts. As mentioned don't 'flip the early CSB since the mounting holes are offset.
                  you can cross reference at http://www.realoem.com/bmw/partgrp.d...3&mospid=47309
                  • Mistawall
                    • Dec 2013
                    • 319
                    what about with the 6 bolt drive shaft where would i mount the e30 CSB
                    my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
                    • orangechicken
                      • Aug 2014
                      • 23
                      Just finished this. The definitive answer for late model E30 318's (at least) using an E36 M3 manual shaft (at least) is:
                      1. Buy the E30 CSB for your year car. These late model E30 318's (among others) have the carrier offset towards the passenger side. (In other words: the short leg of the carrier is on the passenger side.)
                      2. Install the CSB in its stock orientation – not backwards – with the offset on the passenger side.
                      3. *Don't* buy the dust covers / support plates for the E30 CSB, however. Instead, buy the E36 versions (part #s 26 11 1 226 552 & 553, IIRC). Circlip is the same for both, I believe.
                      4. Don't forget to preload the CSB!
                      • zcenterb
                        • Feb 2014
                        • 2105
                        ^+ The e30 CSB dust shields will not sit flushly on the e36 shaft. I pressed my CSB on with a floor jack, ropes, and some PVC piping, but as long as the bearing itself it pressed on evenly you should be all set.
                        CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
                        Instagram: @centerbarmotorsport
                        Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
                        The Fleet:
                        -1984 325ei Lapis
                        -1991 325ix Diamond
                        - 2005 X5 4.4i Black Sapphire
                        -1972 2002tii Fjord - SOLD 7/8/17
                        -1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
                        The Bike:
                        -1980 R100RS Inca
