Starting issues?
  • PuebloPete
    • Oct 2005
    • 161
    Starting issues?
    Kinda weird but was wondering if anyone has seen this. Every now and then, cant quite get a handle on any pattern, I'll turn the key, all the lights come on as normal, and I go to start and it doesn't do anything. I mean nothing. Sometimes it may do nothing for a split second and then turn over and start. If it doesn't do anything, I can shut off my cutoff switch, which will be like disconnecting the battery and turn it back on and it will just turn over as normal. Could it be a relay that's going or something?? Kinda at a loss here. Thanks for any input.
    My build threads
    http://forums.bimmerforums.com/forum....php?t=1435735
    http://www.e30tech.com/forum/showthread.php?t=93896
  • maclogos
    • Jun 2013
    • 120
    Make sure your grounds are clean and tight. Loose grounds will cause non starting issues.
