M52B28 cam regrind and lifters
  • bmartin
    • 15
    I am just about to fit a M52 and thinking about doing some cam regrinds. While I am in there I'll replace couple of lazy lifters. Are there common lighter hydraulic lifters for M5X engines? M42 guys use VW lifters I believe. The M52 has a M50 inlet and big bore TB and is chipped.
  • DesertBMW
    • Aug 2011
    • 1040
    M52 lifters are light enough.
    • Nutzy
      • Sep 2011
      • 102
      I weighed some lifters the other day.
      M50 35mm lifter - 60g
      M52 33mm llifter - 48g
      The M50 lifter was new and probably not full of oil either.
      89 M50B28 turbo
      LINKY
      • Wanganstyle
        • 2828
        Use new stock lifters
        Use stock s52 cams; why bother regrinding when there is already an Oem solution? I know the land down under cannot leave anything alone.....ever!
        Sent from my iPhone using Tapatalk - now Free
