Ever since I swapped a '92 M50NV into my race car, I've had problems with the starter. Occasionally it'll crank at full speed, and every once in a while it won't crank at all, but the vast majority of the time it just cranks slowly. After a few revolutions of the engine, it fires right up every time, so it's a problem with the starter.
I decided to pull all of the electrical connections off the starter and clean them, along with the ground cable from the chassis to the engine. I put it all back together and nothing changed.
Note that I do not have the unloader relay connected to the starter. This is a gutted race car so there's no A/C or power windows to worry about.
The battery tested at 12.6V and I'm getting 12V+ to the starter at the big terminal (battery/alternator connection). I used a starter bypass switch to jump the big terminal to the small one with the starter trigger wire, and it cranked at the proper normal speed. Tried again at the start switch in the car, and it was back to cranking slowly.
I checked the voltage at the smaller terminal with the starter trigger wire, and when using the starter bypass switch I'm getting 10+ volts. I figure that's a normal voltage drop from 12+V when cranking. When I use the normal starter switch in the car, it only gets 7V. That would explain the slow cranking.
Here's a video. You can hear the difference in starting speed and see the voltage difference: http://www.youtube.com/watch?v=PNhO-LfIlII
Where does the starter trigger wire get its signal from, and what determines how much voltage it gets? I looked at the wiring diagram and I'm confused. For what it's worth, the car has a new main relay. Any help is appreciated.
