First and foremost, i got a decent deal on a S52 and ZF 5 speed trans, complete harness, siemens ECM and a few other things, and I want to swap it into my e30. My main question is WHY do people convert it to OBD1 instead of leaving it OBD2? I can understand the intake manifold i guess, but even then, it seems like a lot of wasted time. I have all of the sensors on the engine, and I can get access to any that are not directly on the engine (i have full exhaust with O2 sensors, etc.) having that said, what other peripherals are needed for the OBD2 to work correctly? I planned on getting the EWS out of the car, but also having the ECM reflashed (is that possible/easily done on a siemens ECM?)
Next, I have an 1987 325is with the 3.73 LSD. Should i use the Getrag 260 that I already have and fab up all of my other brackets, or just use the ZF, and what all does that entail, such as rear differentials and other hardware. ( i can also buy the driveshaft) I know that the 3.73 will be geared too high for the ZF, so if i use it, then i need to get a new rear diff (probably from an eta). People who have used and do use the G260, do you recommend it or would you use the ZF? Thanks. I'm trying to do as much research as I can at the moment.
