Hi guys, its getting cold out and for some reason, my m50 swapped 87 325i doesnt blow hot. looked on the firewall and the hoses appear to be hooked up, when i turn the blower motor on, it blows, just not hot. any idea? possible heater valve shut? heater core bad?
heat???
Tags: None
did you bleed your coolant or is it even full?If you're not going to do it right, please don't take it out on your car! -
Yeah everything is brand new too, radiator, hoses, tstat, water pump the whole nine yards. Haven't had any overheating problems either...Comment
Heater never worked under my ownership. PO said it worked before swap, do you think you, or anyone, could maybe take a couple pictures of what their heater hoses look like? I'm just puzzled, searched all over. Thanks again.Comment
