So im just about done my m50NV swap in my 92 e30 convertible.. Im to the point where im trying to start it before i finish tieing up wires etc and i cant get it to fire..
I bought the whole swap from a salvage yard out of a lightly hit 92 525i 5speed car.. I used the entire swap..
This isnt my first time at the rodeo so ive covered all the obvious things, batteries fully charged, the main relays have a constant B+, the engine harness is grounded to the strut tower at the B- post, engine ground goes from the block to the oem spot on the frame rail, fuse box is powered, crank sensor reads 490-500ohms (which i read was correct?) ive triple checked my x20-c101 swap.. And last night i tried my ecu in a friends 92 e36 and her car fired rite up..
What am i missing here? The ecu does not prime the fuel pump and the trigger to the coil packs is only .7v when cranking it.. If i run a jumper to pin 13 in the c101 the fuel pump fires rite up..
I drove the e30 for several months prior with the m20 with zero issues so im leaning towards something in the e34 harness
Any input is appreciated, thanks
