S52 Euro filter housing
  • justin_l_
    • Jun 2007
    • 1079
    Can you cap the ports for the oil cooler or do you have to loop the lines?
  • MyE30
    • Sep 2013
    • 326
    I personally don't have a euro oil filter housing, but I would believe you would have to loop the lines considering that is the path the oil takes (I could be wrong).
    Do you have a euro oil filter housing? If so, why do you want to delete the oil cooling function?? You could always just replace housing with a US spec filter housing. Hell I'll trade you mine.
    • justin_l_
      • Jun 2007
      • 1079
      Temporary solution. The car will have a cooler but need to run it now.
      • justin_l_
        • Jun 2007
        • 1079
        So nobody has a real answer to this?
        • justin_l_
          • Jun 2007
          • 1079
          For future reference there is an internal bypass.
          • vandy
            • Nov 2011
            • 130
            Thanks for actually answering your own question after you find a solution. I hate searching old threads for similar problems to what I'm having only to have the OP say "I'll come update when I fix it"...
            • justin_l_
              • Jun 2007
              • 1079
              Me too, that's why I try to make it a habit. It's even more annoying when they come back and say "fixed it, nevermind"
