Is my transmission crap??
  • Nick_S
    • Apr 2011
    • 3658
    I'll be honest, transmissions are still fairly new to me so I don't know much about them. While cleaning up the G250 I've been planning on using for my swap today. I was messing around after I got my UUC shifter and new bushings on shifting it through the gears. Seems to shift just fine but then I noticed while turning the input shaft, that only in 1st gear, I can hold the output shaft still while turning the input shaft. There is some light clicking from inside as I do this. My G240 I just removed doesn't do this and no other gears do so I'm assuming I've got a busted 1st gear on this thing and I should probably start looking into another option??
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • DesertBMW
    • Aug 2011
    • 1037
    That is correct, you should only be able to hold one end and spin the other in neutral.
    • Nick_S
      • Apr 2011
      • 3658
      Ahh crap, I figured. Well looks like it's back to using the G240.
      05 Honda Pilot
      24V swap thread
