Everything you wanted to know about brake boosters and master cylinders
  • matt
    • 3732
    #46
    Originally posted by B3M2W5
    So if i use the E30 325ix brake booster, I can or cant use my stock MC???
    Or if it is posible can i use the MC i have from the E36 325 ???
    And whats the deal with the remote resivor, :crazy: im confused on why you need the remote res unless its jsut to make room for the intake thats all i could see right?
    You're confused about a lot of things... I was very clear that you cannot use the stock MC with the ix booster. If you would bother to LOOK at the booster in your car and the new one, you could figure out why.
    Matt, PM me if you want to know how to do it right. The 540 brake res is huge and ugly. I have a much better solution I can give you part numbers for.
      • 37833
      #47
      If i might ask where did you get your ix MC ?? i need to start looking for one if i need it
      Bought it from a forum member.
      Grover Beach, California
      BimmerHeads.com
        • 37833
        #48
        Consider yourself PM'd.
        BimmerHeads.com
        • Rigmaster
          • 3464
          #49
          Can the OP or someone update this in a list format??
          Basically, what are the Booster/MC options and the pros/cons of each?
          I read thru the entire thread, but the signal to noise ratio is too high for me to interpret and it's awfully hard to weed out the "I heard this would/would not work" posts vs. the "I've done it and I know this will/will not work"..... :)
          Bret.
          • Jason89i
            • Sep 2004
            • 875
            #50
            ..........it's awfully hard to weed out the "I heard this would/would not work" posts vs. the "I've done it and I know this will/will not work"..... :)
            Bret.
            welcome to the internet. 50% hear-say, 30% speculation, 20% hands on experience. do a search and look for photos of installs.
            all of the conversions i have done (us spec m/s50/2's) used the e21 booster. easy to find, shorten rod via cut and weld (if you are ok putting your existance into your ability to weld) or re-thread (if you have patience and value your life.) you can use the e30 master, e30m3 master or 750i master.
            • FredK
              • 14761
              #51
              I would have killed to be able to remove the E21 booster rod so I could use a lathe to turn it down and thread it. :mrgreen:
              • matt
                • 3732
                #52
                I have never driven a swapped car with the 320i booster, but I have been very happy with the brake feel on the two that I've driven with iX boosters and 25mm master cylinders.
                • Rigmaster
                  • 3464
                  #53
                  Gee, thanks!!
                  • equate975
                    • Jun 2004
                    • 3382
                    #54
                    No you can't. It mounts differently.
                    Yeah your right, I got confused and I was thinking resuse the old IX booster.
                    Did anyone BOTHER to read the FIRST page? I have every written out clearly, what works, why, how, and part numbers.
                    IX Booster:
                    Use the IX MC or the e34 25mm MC. I know EITHER of these WILL work.
                    You need a remote res. Page 1 has the part number. I know this WILL work. Or you can cobble your own together, on your own for that.
                    e21 320i booster:
                    You must cut the shaft down. The object of the game is to make the 320i shaft (which is longer than the normal e30) the same length as the e30 one. Measure your e30 one, measure you e21 one, cut, thread, bolt in. DONE!
                    Then you DON'T need a remote res, just pop whatever one goes on whatever MC you have on.
                    e36 MCs WON'T work, e36 boosters WON'T work
                    EDIT: Shit, I said the e34 m5 will fit the e21 (before my edit) thats not true, Now I remember why I ditched my e21 booster lol.
                    Rollin' with a Geistkuchen
                    • e30_kid89
                      • Apr 2006
                      • 489
                      #55
                      for my remote reservoir set up, i used a 2002 reervoir with the DSM lines...i mounted hte reservoir above the shocktower where the e30 ps reservoir goes...the reservoir almost kisses the hood when the hood is closed. but it works no prob. only cost me $35CAD for the setup.
                      • Rocla
                        • 922
                        #56
                        I've built M50 non vanos to e30, trimmed fins from intake plenum, shimmed stock booster to lean little to left= some 3-5mm gap. My friend drove with that assembly for 15kkm and had no problem, but it is a tight fit, and due tolarances it might not work in all cases.
                        Current:
                        BMW 320i 2d 2.0 m20 -88
                        BMW 325i Cabriolet 2.5 m50 -88
                        BMW 316i touring 1.6 m40 -90
                        BMW 320i 4d 2,2 m54 -01
                        • nismoman
                          • Jul 2006
                          • 246
                          #57
                          what about your clutch resevoir?? on the e cars. on the e cars using the getrag you have your hydrolic feed line running from the resevoir thats on top of the master cylinder. what are you guys doing about that???
                          1985 s50b30, 91 front and rear valence, e30 m3 suspension, advance design coilovers, GC camber caster plates full solid bushings alla round, adjustable rear arms, ireland sways front and back, ireland big brake kit front and back , team dynamics wheels, 24lb injectore ltw fly, intake , headers, exhaust, so forth so on......
                          • triggrhaapi
                            • Feb 2007
                            • 350
                            #58
                            IX Booster:
                            e21 320i booster:
                            Well, I have just recently come up on a deal for an ix booster and mc for $80 shipped, which I jumped on. Just to be absolutely 100% sure... that will work with a remote reservoir setup, correct?
                            1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              #59
                              That's where I am at now, so what is the best way to do this, the machinist said I was on my own. :sad:
                              Originally posted by 325Projectz
                              don't listen to the diagram... listen to mr. swiss.
                              :nice:
                              • triggrhaapi
                                • Feb 2007
                                • 350
                                #60
                                I found an IX booster and MC for around $80 from my buddy bill over at MSR. Call him at 201-675 6658 and see if he can get you one. If he can't I know he can find someone who can. Tell him Jason sent you.
