Ok once and for all, here it is!
Option 1:
Use the e21 booster
Pros: Reuse old Master Cylinder, No remote reservoir
Cons: You will have to cut the shaft down to match that of the stock booster. Supposedly, will not give full lock to the brakes
Im not going to say much about this, because its a stupid way to do it.
Option 2:
Use the e30 325IX booster.
Pros: Its better than the e21, double drum design
Cons: Remote reservoir
How To:
Get yourself an e30 325IX brake booster, I used an e34 m5 master cylinder part number 34331156978.
For the remote res.
http://www.realoem.com/bmw/showparts...34&fg=25&hl=15
GET THESE:
05 EXPANSION TANK GIRLING 1 34321160576
02 PLUG 2 34311163464 WILL NEED TWO OF THESE
Here is the parts
Put your booster and new master cylinder together, then it all just pushes together
I found that where I have my reservoir now, the lines can get caught in the throttle body linkage, also they get in the way of the intake boot
The best place I can find to mount it would be on the plate where the old airbox attached next to the ABS unit
Option 1:
Use the e21 booster
Option 2:
How To:
For the remote res.
GET THESE:
Here is the parts
