OBD 2 vs OBD 1 for better tuning and annual smog tests.
  • surebimmer
    • Jan 2004
    • 978
    So here is the background I have had my S52 OBD 1 swap for well over 6 years now. My swap is California BAR certified. I got new magaflow cats two years ago and then this last week i had to do the same thing to pass smog. $400 bucks for cats every two years is getting old.
    I'm thinking of converting to OBD 2 for better tuning and drivability. OBD 2 has two O2 sensors on each banks manifold, vs OBD 1 that only has 1 02 sensor after the two banks meet. Does anyone in California have a OBD 2 BAR legal swap? Do you have any smog printouts? OBD 2 also offers better diagnosis of any problems with the car.
    Thoughts on OBD 2 vs OBD 1?
    Ballpark cost to convert from OBD 1 to OBD 2? I'm thinking ball park OBD 2 engine wire harness $100-150, OBD 2 DME $60-100, OBD 2 tune $350, 2 post 02 sensors $200 bucks.
  • DesertBMW
    • Aug 2011
    • 1037
    Why not, build them as bolt ons and make test pipes, so you go pass emissions, then unbolt them and put the test pipes on, then after 2 years you don't have to waste another $400? You got to be smart if you want to save money.
    or:
    Run MS41.2 system, use stock S52/M52 metallic converters, run the secondary air pump and you never have to worry about converters going bad.
    • Aviator
      • 616
      ^Exactly.
      84 325e Burgundrot S52 M Tech 1.
      http://www.r3vlimited.com/board/showthread.php?t=250109
      • e30austin
        • 15382
        Or just run stock OBD1/2 cats on your current setup......
        I am hugely in favor of OBD1, it is a simple system that works well. OBD2 just over complicates a car that doesn't need to be. IMHO, at least.
