High mile M52 Rebuild kit help!
  • AlexHale
    • Nov 2012
    • 230
    I have a M52 with a 198000 miles on it, where can I find a rebuild kit or all the components? Thank you,
    Originally Posted by Exodus
    He also kept asking why someone local didn't just go to the guys house and break his kneecaps, as they would do in Romania. He couldn't understand how us Americans are so laid back about shit like this.
  • hooken m
    • 1537
    do you know if the previous owners ever had to replace the head or anything major? cause otherwise it might cost a pretty penny. do you know the compression numbers on the engine? are you planning on doing the work yourself or a machine shop?
    Originally posted by evandael
    a car is a car. call it a dildo, i'd still drive the hell out of it.
    • AlexHale
      • Nov 2012
      • 230
      No, the car has been in my family since new, however at 19800, we feel,it's time for,a refresh. We've never had any problems with the motor no vanos failures or anything. I'm not looking to bore, stroke, or,anything fancy. Just a budget rebuild,the compression should...be fine, the car was driven today.
      Ideas?
      • AlexHale
        • Nov 2012
        • 230
        I will do the work personally
        • DesertBMW
          • Aug 2011
          • 1033
          Ideas?
          If there is no ridge on the top of the cylinder bores and stock engine bearings look ok, then all you do is slap on new piston rings, engine bearings, chain, guides, seals and gaskets. That's it. You would need new plastic valve cover for sure, they are warp by now.
          • Mistawall
            • Dec 2013
            • 319
            would this apply to the s52 as well? i just picked one up with 184,000 and i want to give it some TLC before i put it in my e30. no codes pulled from a rolled m3 automatic… but i figure might as well do it once, do it right?
            my build thread http://www.r3vlimited.com/board/showthread.php?t=309778
            • Wanganstyle
              • 2828
              Pull head drop off at engine shop to have built. Many in the bay area equipped for this.
              Leak down each cylinder and see what the status of rings are. If leakdown is good then just install head and go
              If leakdown is not in acceptable range tear it apart and change rings and or pistons. Bring to professional engine shop for measuring and cleaing and work.
              Sent from my SAMSUNG-SGH-I337 using Tapatalk
              • amcink
                • 788
                I have good cams for sale
