m50 & m52 harness wiring
  • Mr Mpower
    • Aug 2011
    • 95
    Hi guys! i have my m10 engine out of my 1983 318i e30 and i have the new engine in front of the car, it's a m52b28.
    I have a few harness in a box, i think one is from a m50 e34 and the other is m52 e39 i think...
    i dont know how can i know where i need to plug all the wires, i think for know i want to go m50 obd1 route because maybe it's easier and fast and i dont have the m52 ecu but i have the 413 red label m50 ecu.
    can you give me some help?
    thanks for all!
    https://twitter.com/PetrolHeadSpain
    http://spainpetrolheads.wordpress.com/
    https://www.facebook.com/PetrolHeadsSpain?fref=ts
  • Mr Mpower
    • Aug 2011
    • 95
    ok, i've found this here
    oil pressure sensor BRN/GRN or BRN/GRY
    front coolant temperature sensor (ECU) BRN/RED BRN
    rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
    crank position sensor YEL
    cam position sensor YEL RED/WHT BRN/ORG
    VANOS solenoid RED/WHT GRN/BLU
    knock sensor, 1-3 BLK NCA DME PIN 70
    knock sensor, 4-6 BLK NCA DME PIN 69
    throttle position sensor (TPS) BRN BRN/BLK RED/YEL
    intake air temperature (IAT) sensor BRN GRY
    idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
    Evaporative emissions valve BRN RED/WHT
    but i have a few questions, i dont find evaporative emissions valve and cranck sensor exactly.
    now i only have three wires without name
    1.white/brown white/grey white/red (maybe evaporative emissions?)
    2.blue/white brown/orange blue yellow (maybe oil pan)
    3.yellow black and a third wire who is like yellow or gold
    and for the knock sensor i can't identifi which are 123 or 456
    thanks for all!
    • Wishno87
      • 6025
      I'm having the same issue with the knock sensor plugs.
      • FredK
        • 14762
        Look at the DME connector.
        Using a voltmeter, check continuity between pin 70 and the knock sensors. The knock sensor continuous with pin 70 is for 1-3. Pin 69 is for 4-6.
        • Mr Mpower
          • Aug 2011
          • 95
          nice answer..thanks!!
          anyone have the same colour diagram for the m52 harness?
          • Wishno87
            • 6025
            Awesome! Thanks for that.
            • Mr Mpower
              • Aug 2011
              • 95
              well and this is for m52 i think..m52 dont have oil pressure sensor?
              throttle postition brown black red/green
              idle control valve red/white white/yellow white/green
              intake temp sensor grey gre/brown
              evaporative emision valve red/white brown
              Ecu temp sensor grey/brown brown/red
              cluster temp sensor brown/yellow brown/violet
              camshaft position black brown yellow
              crankshaft position sensor black yellow brown/black no lo localizo
              knock 1-3 yellow black
              knock 4-6 green brown
              carbon canister red/white/yellow green/blue
