Need E34 to E30 compatibility help..
  • bladsville
    • Dec 2013
    • 11
    I purchased a running E34 525i to swap its drivetrain into my 89 325i. Im gathering parts, as well as information. I already figured out wiring, mounting, and everything else, but since im using the E34 transmission, i cant find solid information on a couple of things.
    What driveshaft do i use?
    What shifter assembly do i use?
    Any help would be GREATLY appreciated!
  • Nick_S
    • Apr 2011
    • 3656
    Do those use the getrag 250? If so I'm pretty sure you use the linkage from the transmission you're using.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • bladsville
      • Dec 2013
      • 11
      I really dont know what they use, some people say the 250, some people say the ZF. Just trying to get some answers so i can get the correct parts ordered!
      • JOMARO
        • Mar 2006
        • 116
        as far as I know the non vanos ones uses the ZF
        • bladsville
          • Dec 2013
          • 11
          The E34 that i pulled the motor from was a 1994 and it has VANOS..
          • surebimmer
            • Jan 2004
            • 978
            Can you look at the transmission and see if it says ZF or getrag?
            • bladsville
              • Dec 2013
              • 11
              It says getrag.. Anyone know what shifter assembly and driveshaft I should use?
              • bladsville
                • Dec 2013
                • 11
                Anyone?
                • Poeman446
                  • Jun 2013
                  • 227
                  Im going to assume that you will use the driveshaft out of the 525i. Im not 100% sure on that, but I am pretty sure you will use the 525i DS. As far as the linkage, also use the one from the 525i. Im guessing though, but as a general rule, use the Driveshaft that comes with the transmission you are swapping in.
                  • bladsville
                    • Dec 2013
                    • 11
                    I was just under the impression that since the 525i is a longer car, the driveshaft would not fit my E30..
                    • Poeman446
                      • Jun 2013
                      • 227
                      Hmmm... it might not. If you are using a M50 and Getrag 250, then an E36 manual driveshaft will work. I'm not sure if they are the same as the DS from the 525i. A search on realOEM or Pelican parts should tell you.
                      • bladsville
                        • Dec 2013
                        • 11
                        Would the stock E30 325i DS work?
                        • haggardfab
                          • Sep 2011
                          • 283
                          I have an e34 drivetrain in my e30, i used the shifter linkage from my stock e30 trans and i just shortned the e34 shift support rod because i have the tools to do so but the e30 one may bolt on to the e34 trans..
                          For the driveshaft i used the Revshift adapter guibo and kept my e30 driveshaft.. Way easier then trying to piece together driveshafts or find the correct e36 one
                          IG: haggardfab
                          • bladsville
                            • Dec 2013
                            • 11
                            Was your E34 equipped with a ZF or Getrag Transmission?
                            • haggardfab
                              • Sep 2011
                              • 283
                              ZF but that stuff should be the same for both trannys id imagine
                              IG: haggardfab
