Apparently I need someone to explain the brake booster relocation like I am a five year old. I got the holes drilled .5" towards the drivers side, fit the booster in, and got the pedals in. The brake pedal linkage hooked up as it normally would, but the clutch master has clearance issues. When I put the clutch master cylinder through the firewall, it hits the brake booster. Some said that they had to cut off one of the studs on the booster, but I haven't had to do that, and it fit in very well.
Did I drill my holes too far to the right? I measured 1/2" over from the edge of the first hole to the center of the other, as that's how I assumed it would be measured.
Do I need to mount the pedals back in the factory holes, and shift my brake linkage between the pedal and the factory mounting tab?
I feel like an idiot because I can't drill holes and mount a brake booster and pedal box.
Thanks.
Thanks.
