when doing the m50 swap into a 90 E30 325is what is the complete list of everything i should pull from the 325i? i cant get the tranny, it will have to come from a different car.
the IS has a 3.73 so with the 1:1 5th gear my revs will be a bit high, but oh well. is there a 2.93 that is an LSD available from one of the models?
I know i need:
m50 engine
all accessories bolted on engine, i.e. a/c power steering pump, fuel injectors
wiring harness for engine
what relays or other parts should i get from the 93-95 325i?
The motor mounts and bolts? the trans mounts?
Thanks,
Justin
I know i need:
m50 engine
Thanks,
Justin
