What Did I do wrong? S52 Oil filter/housing
  • ZekeTheSneak
    • 1562
    Oil everywhere, oil is leaking around the caps seal. Everything has less than 1000 miles on it.
    I think I installed something wrong or maybe I have the wrong filter? I bought the filter kit from pelican.
  • NbAmTwE
    • Jul 2010
    • 148
    that copper washer??? Idk if that's the right washer. There are two washers that come with them, the smaller one, whichever one barely fits the bolt is the correct one to put on this bolt. There other is for drain plug. Also you could have just tightened it too much. I did that before. I hand tighten it and then given it a little 1/2 turn or so at the most and it should center the cap and create a strong seal.
    UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
    stripped out e30 rally project - in progress
    M50NV -> M50TU E34 swap underway
    • MC Hammered
      • Jul 2008
      • 2076
      I just looked at my OEM filter kit and I believe NbAmTwE is correct, the copper washer does on the drain plug and a smaller silver one goes on the oil filter cap bolt.
      My 1989 e30 s52 Touring... this is Betty
      My 1989 325i vert (sold)...this is Nina
      My 1991 M5 (sold)... this is Veronica
      Photo comparison: OEM vs aftermarket windscreen for a convertible
      • ZekeTheSneak
        • 1562
        word. Ill see if I can find it.
