OBD1 m52 no crank, no ICV hum, no nothin'
  • Roysneon
    • 4505
    So my setup is
    OBD1 M52, using the same harness and DME that I had on my old m50. I labeled everything as it came off the m50 and hooked everything back up the same way on the m52.
    I have power to the big starter wire
    The relays on the wiring harness have power
    The harness is grounded on the strut tower
    The engine is grounded off the motor mount
    When I turn the key to 'on', the fuel gauge moves but when I turn it to start I get no change at all
    Dafuq
    Originally posted by mbonanni
    I am a pursit now.
  • Kingb
    • 928
    Could be your ground. Even tho the cable is hooked up it could not be poviding enough ground. Take some jumper cables and hook one side to the engine and the other to the body. I've had issues like that.
    Originally posted by Nicademus
    My car beats off to that car. :bow:
    • justin_l_
      • Jun 2007
      • 1079
      Your pump prime when you turn the key on?
      • Roysneon
        • 4505
        Not a thing.
        I am a pursit now.
        • justin_l_
          • Jun 2007
          • 1079
          You sure all the grounds are connected and you didn't ground a power wire that is black? Also.... how is your battery?
          • Roysneon
            • 4505
            I have power to the starter terminal and to all the harness relays. Even if there was a sensor not installed or plugged in correctly, the starter should at least turn. I have the fuse box to the positive terminal and the harness ground is securely grounded on the strut tower.
            I am a pursit now.
            • Roysneon
              • 4505
              So I finally decided to fuck with this thing again.
              Jumped power from the main stud on the starter to the lower stud with the smaller wire and the bitch started up. So yay.
              Now what would cause it to not get power to that wire when the key is turned? Bad starter relay?
              I am a pursit now.
              • justin_l_
                • Jun 2007
                • 1079
                Could be, is it getting signal from the ignition to the relay? Anything from the relay when you turn the key? Trace it back from the starter and see where it stops.
                • Habla
                  • May 2004
                  • 1470
                  Do you have a 3-post starter? If so, make sure the terminals go to the posts that are closest in size. The big post is obvious, but the two smaller wires go to their similar sized posts. I forgot to hook up the 2nd biggest wire (which activated the starter solenoid), so the starter didn't engage the flywheel.
                  -Peter
                  318is slicktop | F15 35dM | F250 SD
                  • Roysneon
                    • 4505
                    I am 90% sure that I have both wires hooked up and that they are on right. Mine were two different sizes so it wasn't possible to put them on wrong. I'll try to get a helper to turn the key while I check for power with the multimeter.
                    I'm just happy to have this bitch make some noise.
                    I am a pursit now.
                    • Roysneon
                      • 4505
                      Also the fuel pump only primed or kicked on when I jumped power like that. Could a bad ignition switch or relay cause that?
                      I am a pursit now.
                      • Habla
                        • May 2004
                        • 1470
                        The DME wont power the fuel pump if the engine is unable to start. When I tried to start it with the starter wired incorrectly, there were only three relay clicks, no icv hum or fuel pump hum.
                        -Peter
                        • Roysneon
                          • 4505
                          I'll take it off again and double check, then. At least I know all the other wiring is good now.
                          I am a pursit now.
                          • Roysneon
                            • 4505
                            Is there anything else besides the unloader relays that supply power to the starter solenoid?
                            I switched the wires and nothing. There is also no voltage to either of the smaller two wires.
                            Also, before the swap, the starter would sometimes spin, but not engage the flywheel, so I think a relay somewhere was slowly on the way out and quit while it sat.
                            I am a pursit now.
                            • e30austin
                              • 15382
                              I would try a new starter.
