Having trouble figuring out what's going on. I replaced my clutch slave cylinder a few days ago because it was leaking, and bled the system using a vacuum bleeder from the slave. Everything was golden until a few hours ago. The engagement point of the clutch pedal shifted higher when I was driving. The first thing I felt was like it had no pressure. It then quickly built up again and the engagement point had moved further away from the floor. I've owned the car for a year and the engagement point had always been fairly close the floor, engaging about an inch or two off. Now it engages about 4 or 5 inches from the floor.
Please let me know your thoughts, or if I need to explain anything more clearly!
Thanks in advance!
Thanks in advance!
