I have a 1987 BMW 325is - but the car has a motor and transmission swap. The engine is a 1997 M52b28 and ZF 5-speed transmission from a 1997 328is.
Here's my problem. I'm having serious hesitation issues and a hunting idle. The hesitation occurs only under heavier acceleration (around 60% throttle or more) at low rpms (around 1500rpms to 3000rpms) and again at higher rpms (around 5000rpms up to redline). If I'm light on the throttle it doesn't hesitate at all. Also when its cold, and sometimes even after it's warmed up, it will not idle smoothly. The rpms fluctuate from about 600rpm up to 1000rpm back and forth.
I'm reading that these symptoms are tell-tale signs of a vanos unit that is malfunctioning. Does this sound familiar to anyone? At first I thought maybe it was my fuel pump or fuel filter going bad, but if that were the case then the mid-range rpms would have the same problem right? The fact that it's occurring at low, fine in the midrange, then again at high rpms leads me to believe it's not a fuel issue?
I think I'm going to buy the Dr. Vanos stage 1 single vanos kit. What else do I need to buy? Valve cover gasket, seals, cam blocks, locking pin, etc... ?
Thanks
Thanks
